Re: serial number on H
Posted by CNKS on September 25, 2004 at 09:56:23 from (207.178.99.156):
In Reply to: serial number on H posted by bhb on September 25, 2004 at 07:57:03:
IH did not attempt to match serials on the chassis and block on either H's or M's. But, on early models they were usually identical. The numbers do indicate how old the engine is, the higher the number, the newer. If you have a chassis serial with a 5 digit number, and an engine serial with a 6 digit number, the engine has been changed. A parts book is quite helpful in determining which parts fit -- if there is a difference the book will list the serial number breaks. In any case, when determining engine parts such as pistons, sleeves, etc, it is always better to measure.
Post a Followup
Subject:
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
