Re: Not alot of charging? on w4
Posted by jasoninpa on September 25, 2004 at 16:09:39 from (152.163.101.13):
In Reply to: Not alot of charging? on w4 posted by Bob Quale on September 25, 2004 at 09:30:00:
voltage is not as much concern as amps ive had problems with my Farmall H witch is the same as a W4 tractor if you have a high/low charge control the amp meter should show around 2 amps on low and 12 amps on high to adjust speed at which gen. kicks on you make the point gap in the voltage reg. closer it will take some engine speed to excite the gen. mine you need 1/2 or so engine speed to kick on but then you can go almost to idle and gen. will stay on there is also a resister wire in voltage reg. (if origanal) that wil regulate rate of charging if you replaced the reg. with a newer type that can cause problems because the origanal system is a single wire type and the new style reg. has an excite wire witch i could never get to work properly and ended up having the shop fix my old reg. and now it works fine. if your gen. is putting out a cherge its good and just need to find out why your not get voltage and/or amperage to battery also the high/low switch could be bad or rusted inside and that will cause bad contact.just remember amps are more important then voltage they are slow charging systems 7.5 volts is more then good 6.5 is still exceptable and that would be wide open readings.with amps wide open would be 2 on low 12 on high please. let me know how youu make out or if you need more help i know what its like i pulled my hair out for over a year to get mine fixed right and leared alot along the way.
Home
| Forums
Today's Featured Article -
Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
