Re: Not alot of charging? on w4
Posted by El Toro on September 25, 2004 at 18:15:41 from (216.148.244.70):
In Reply to: Not alot of charging? on w4 posted by Bob Quale on September 25, 2004 at 09:30:00:
Hi Bob, BobM has an excellent flow chart for troubleshooting generators and regulator problems.
He has been very generous to post that.
http://albums.photo.epson.com/j/AlbumIndex?u=4001561&a=30065733&f=0 An output of 8 to 8.5 volts is ok on a 6 volt system. Good Luck, Hal
Post a Followup
Subject:
Today's Featured Article - Storing Your Tractor - by Staff. If your tractor is going to be stored for any length of time, a few precautionary measures are helpful in preserving various parts, also in avoiding future difficulty. Store tractor under cover. If impossible to place tractor under cover, be sure to cover air stack and exhaust pipe. Drain radiator and engine block. To avoid gum content collections, drain both fuel tanks and carburetor. Leave radiator and fuel caps slightly loose to protect gaskets. Block tractor up to remove weight from tires and to keep tires from contact with moist floor. ... [Read Article]
