Re: 560 disc brakes questions
Posted by catmandoo on September 25, 2004 at 20:55:42 from (216.254.237.104):
In Reply to: 560 disc brakes questions posted by Lance R. on September 25, 2004 at 20:47:50:
on my 460 i had to replace the springs and the ball tracks should be smooth,if pitted and rusty the balls can hang up causing the grabbing,i put them in dry they get worked pretty good if you use it and they should keep clean and rustfree,if you do use a grease the brake dust just tends to stick to the grease then you have a mess,as for the housing i have seen people weld them how they work i don"t know,i"d probably check salvage yards for a different one.
Post a Followup
Subject:
Today's Featured Article - Trailering Your Tractor - by Curtis Von Fange. One of the fun things of summer and fall are the parades and tractor shows that go on across America. Many owners of tractors travel long distances to attend these shows and they usually take their restored iron along with them. Safe trailering practices and inspections will ensure that the event is a fun one. A good habit to develop when using a trailer is to give that ‘quick look over’ before taking it on a trip. Before hooking up to it check the tongue for proper operation. The latche ... [Read Article]
