Re: 560 disc brakes questions
Posted by Lance R. on September 26, 2004 at 04:09:34 from (65.166.133.52):
In Reply to: Re: 560 disc brakes questions posted by Hugh MacKay on September 26, 2004 at 02:21:48:
Hugh, How smooth should those auctuator plate braking surfaces be before I put this back together? Mine are a little rough. Can the housing crack be successfully welded? The crack starts at the outlet hole opening and is about two inches long so it isn't to the braking surface yet. Do you just use regular brake cleaner to clean this?
Post a Followup
Subject:
Today's Featured Article - Trailering Your Tractor - by Curtis Von Fange. One of the fun things of summer and fall are the parades and tractor shows that go on across America. Many owners of tractors travel long distances to attend these shows and they usually take their restored iron along with them. Safe trailering practices and inspections will ensure that the event is a fun one. A good habit to develop when using a trailer is to give that ‘quick look over’ before taking it on a trip. Before hooking up to it check the tongue for proper operation. The latche ... [Read Article]
