Re: Float Adjustment Help Needed
Posted by CNKS on September 26, 2004 at 17:40:23 from (207.178.96.214):
In Reply to: Float Adjustment Help Needed posted by Jerry Ward on September 26, 2004 at 17:27:39:
Service Manual says 1 5/32, you are at 1 12/32. The top of the float should be roughly horizontal. Measurement is with the gasket installed, can't tell if yours is or not. If you don't use the tractor a lot, it is hard to keep the plugs clean as there is no main jet adjustment. In which case you might want to use more than 1 5/32, but probably not that much.
Post a Followup
Subject:
