Re: Double acting hydraulic piston off a single sp
Posted by MM_TX on September 27, 2004 at 06:59:23 from (69.152.227.171):
In Reply to: Re: Double acting hydraulic piston off a single sp posted by clanger on September 27, 2004 at 06:40:40:
If you have the single spool already in use you need another
spool. Each spool will control one thing with up and down
pressutre or only up depending on how it is set up. Forward up
& back down or back up & forward down depending on
plumbing. Search the archives. There is a lot of info that will
make it all make sense. There are a lot of options & applications.
Post a Followup
Subject:
Today's Featured Article - Talk of the Town: Miracle Formula for a Stuck Engine - by Edited by Kim Pratt. Another great discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: I have a stuck 4 cylinder engine. Two pistons right at the top, other two down. From underneath everything looks good. Up top looks bad. Thanks in advance." ... [Read Article]
