Re: Double acting hydraulic piston off a single sp
Posted by CNKS on September 27, 2004 at 07:19:24 from (207.178.96.214):
In Reply to: Double acting hydraulic piston off a single spool? posted by clanger on September 27, 2004 at 06:27:57:
If you want 2-way hydraulics, you need two ports. If you can get by with gravity for the release, you can use the opposite direction to angle it with the single port you have. I am not at all familiar with the 484. Some tractors can be set up to handle either double or single acting cylinders simply by turning a valve.
Post a Followup
Subject:
