W6 losing power?
Posted by Chadd on September 29, 2004 at 13:10:21 from (155.92.196.202):
The other day I began to notice that our W6 seemed down on power. It was pulling a half of a load of hay, and had the governor opened as far as it would go to keep the thing moving up a hill in road gear with no baler. It almost felt like the wagon had a flat tire or an axle with bad bearings. I checked both and neither were the case. Also, when you are adjusting the governor control lever from about 3/4 to full throttle, it will hiccup and then come back to life. I was wondering if the carb was set wrong. It never smokes any color, but you can see transparent "heat distortion" out of the muffler at all times. I set it according to the owners manual for an M with the adjustable manifold for gasoline or kerosene, even though our W6 has the high compression gas motor. It always runs at just under the line between cold and warm on the temp gauge. I don't know if this helps, but I set it on a colder (60 degree) day. When it just starts in the morning, it idles smoother than my car. After it gets warmer from work, the idle starts to get rougher, with the rain flap popping up in the air occasionally with a backfire or two. The harder it works, the more the rainflap seems to pop up. I always runs fine when it is moving, though. Or could dragging brakes cause it? After driving on the road, the right one gets hotter than the left. If someone has any ideas, they would be very appreciated. Do the settings for kerosene and gasoline tractors differ from the tractors with just gasoline? I was also wondering how fast the PTO turns on everyone else's W6. At about 3/4 throttle, the baler will toss a bale over the back of our wagon(which holds 170 bales). It even shot a bale through the back of an old wooden wagon. Our 806 and 966 will only get the bales just to the back at about PTO rpm. Are all W6's set this fast, or is the engine just overrevving that far? It hasn't had the engine rebuilt since the 60s and has the correct IH governor spring in it. It does outrev our 1940 M. Any help would be greatly appreciated.
Home
| Forums
Today's Featured Article -
Check Your Coolant - by Bill Radford. Great tips on how and when to check the coolant in your tractor.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
