Re: Fire Crater Pistons + 100 vs 140 crankshaft
Posted by Stan(VA). on September 30, 2004 at 12:33:57 from (69.19.0.1):
In Reply to: Re: Fire Crater Pistons + 100 vs 140 crankshaft posted by Ramon from NC on September 30, 2004 at 07:46:24:
Ramon, You can check for a dome by peeking through a spark plug hole while rotating the piston by TDC. Bore can be checked from underneath by dropping the pan (a little easier than pulling the head), and that allows you to get the bottom plate on your oil pump milled flat then replace it's gasket. That bottom plate does warp and then the gasket blows out and looses a fair amt of pressure right there. I would at least verify that the rod caps are all in the right place (numbers stamped on camshaft side of rod and cap should all correlate). If the oil pump bottom plate is in good shape (meaning no problems there)I would look closer at the bearings; otherwise, maybe leave well enough alone. Also, if you're not already, look into heavier oil, 30 weight or 20W50 can also help in an average wear situaltion. Stan(VA).
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
