Re: Hey Stickler-666 Loader
Posted by Stickler on September 30, 2004 at 14:38:41 from (142.165.92.76):
In Reply to: Re: Hey Stickler-666 Loader posted by CEB on September 30, 2004 at 11:36:56:
It's running from the single remote to another set of control valves. Anyone know where the relief valve is on the main pump? The valve are greeson/greesen/greisen/whatever. Would there be adjustments on them as well?
It'll lift a 1500# bale about a foot off the ground, then stops like it's out of pressure. same if you try to use down pressure to lift the tractor's front end......from what little I know about hydraulics, it should be good for more than that.
Post a Followup
Subject:
