Super C oil burner solved...
Posted by BillWV on September 30, 2004 at 18:56:32 from (129.71.136.231):
...I think.
I had time to drain and drop the oil pan this evening, and took out the worst looking piston. Now I didn't have much time before dark (working on it outside for now) but the one ring gap that I got to measure was 0.08". I don't know what the book calls for on the Super C, but the 113 engine specs, which I would think would be similar, are 0.01-0.018". The piston-to-cylinder clearance also appears to be excessive. In the coming days I'll measure the bore and check piston clearance, but for right now, looks like I need sleeves and all. The cylinder bores have a little pitting; the one rod bearing I looked at is slightly grooved, but the crank throw looks smooth.
Thanks to all.
Bill
Post a Followup
Subject:
