Re: WOW! Lost steering on my 400.
Posted by John In Iowa on September 30, 2004 at 20:02:19 from (199.108.167.214):
In Reply to: WOW! Lost steering on my 400. posted by Kelly C on September 29, 2004 at 20:08:35:
Kelly,
It looks like there is no roll pin holding the yoke on. It just looks like the yoke just came loose of the shaft. (which out of 3 power steering units that I worked on that were on 400 and 450, only one had a roll pin to keep the shaft from coming off) There is a collar on the steering shaft just behind the support of the steering shaft just in front of the steering wheel. This keeps the shaft from moving back away from the unit. I'm guessing that the collar was loose and let the yoke work off the power steering unit.
John In Iowa
Post a Followup
Subject:
