Re: Rebuild on DT361
Posted by farmall chad on September 30, 2004 at 20:13:42 from (66.133.189.69):
In Reply to: Re: Rebuild on DT361 posted by Dan 806 on September 29, 2004 at 20:49:46:
Hey Dan,
I am from Wisconsin if that matters but anyway the 1456 pump was a 4 roller pump vs the 1206 2 roller pump...From what I understand the two more rollers increase the fuel flow considerably and should get my 1206 up and going...Ever heard of Inject Tech in Iowa??? Supposed to be a good diesel pump shop, considering talking to them.. Do you know of any good suppilers to get motor parts for my 361? Performance parts? Larger pistons, roller rockers, larger valves...I decided to go all out on this tractor...give the 1066's a little run if I can..
Thanks for the replies Dan nice of ya.
Chad
Post a Followup
Subject:
