Re: Take a look and tell me what it is.
Posted by Big Don on October 02, 2004 at 09:08:59 from (24.114.127.181):
In Reply to: Take a look and tell me what it is. posted by Okie Dave on September 30, 2004 at 19:56:59:
Dave,
I am almost positive that your tractor is a 364.
To the best of my knowledge, the 364 and the 444 British are the same basic tractor. The 444 British was imported and sold in Canada with the BD154 in the diesel and the BC144 in the gas version. At the same time, the US needed a tractor in that size range and they had previously used the 444 model designation so they called the British 444 a 364. Your tractor has inside check chains which is a US type of hitch, while the 444 British that came to Canada had the outside style check chains on the hitch.
The 354 diesel uses the BD144 engine. As a result, I would conclude that you have a 364.The 444 British that was sold in Canada was rated at approx. 38 PTO horsepower but some were "HOT" and would put up 45 or so. I assume the 364 was the same specs. The serial number contains the model info but without a pricebook from that era I can't tell you what it means. The first part of the number is a Kind 43 and code 0003 which was the IH ordering codes and thus the model but they never used these numbers in the after sales support system as a way to identify the unit.
Don
Post a Followup
Subject:
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
