Re: Motor Break-in
Posted by K.B.-826 on October 04, 2004 at 19:35:24 from (209.163.43.112):
In Reply to: Motor Break-in posted by Bubba on October 04, 2004 at 09:28:47:
If you checked an IH manual, it would tell you something similar to this- Start engine, check for oil pressure, check for leaks. Now, hook to the dyno and run half throttle 1/4 load for 20 min-half hour. Then go to 3/4 throttle, 1/2 load. for half an hour. Then go to full throttle, 3/4 load for half an hour. Now let it cool down for a couple minutes, shut it down, and retorque the head and reset the valves as soon as it is cool enough to work on. Then start it up, warm it up for a couple minutes, then go for full throttle full load, for at least an hour, the longer the better.
Post a Followup
Subject:
