Re: Will an IH 464 diesel handle a 2 bottom plow?
Posted by K.B.-826 on October 04, 2004 at 19:50:24 from (209.163.43.112):
In Reply to: Will an IH 464 diesel handle a 2 bottom plow? posted by Chad Lauer on October 04, 2004 at 19:12:37:
Off the top of my head, I think the 464 is about 45 horsepower. For 2-3 acres, you should have no problem with any of the implements you listed. If you worry about it being a utility tractor, just think about all of the 8N Fords out there that did all of the same things that you plan on, on much larger acreages.
Post a Followup
Subject:
