Re: Farmall Super C Hydro Lines
Posted by BillWV on October 05, 2004 at 04:53:52 from (129.71.139.28):
In Reply to: Farmall Super C Hydro Lines posted by RPM on October 04, 2004 at 21:37:05:
My '52 Super C has had the lower pipe silver soldered previously on the end bolted to the pump. It also has a leak up front somewhere, haven't decided yet if it is a leaking o-ring, seal, or the solder needs redone. I would think that with the low temps used for soldering that it wouldn't hurt the flange. If you were worried about distortion, you could take lines off and bolt them to a big steel plate to dissipate heat and prevent warping.
Good luck,
Bill
Post a Followup
Subject:
