Re: Farmall C263 H.P. ?
Posted by Wardner on October 05, 2004 at 10:35:19 from (64.136.49.228):
In Reply to: Re: Farmall C263 H.P. ? posted by Tom in Mich. on October 05, 2004 at 09:48:15:
I don't have a 606 parts book to compare with my 504 book. However, I think you will find that both tractors use the same sheet metal and rails. The F504 has gobs of space to fit a larger motor.
I am guessing the only difference between the two tractors is the motor and radiator. Maybe the clutch. Anyway, I think it is likely that you still have the original radiator which is probably undersized. That may not be a problem unless the tractor is worked hard in hot weather.
Post a Followup
Subject:
