Farmall Tractors Discussion Board
Re: 45 FARMALL A ***WON'T START***
Posted by Phil Auten on November 15, 1999 at 06:57:32 from (206.175.72.226):
In Reply to: 45 FARMALL A ***WON'T START*** posted by TJ on November 14, 1999 at 17:16:09:
TJ,
The spark should be bluish white if it's a good strong spark. If it looks yellowish, it's weak. You may need to clean the points with some alcohol and a new dollar bill. If that doesen't work, check all the plugs and replace them if they are carboned over as this will give the spark another path to ground. Finally, have the magnets in the mag recharged at a shop that specializes in electrical stuff for cars/trucks. You may have to look around to find one in your area, but there is most likely one there if you look.
Good luck,
Phil
Post a Followup
: Re: Re: 45 FARMALL A ***WON'T START***
