Re: Left tractor tire sticks when cold
Posted by Novel Idea Guy on October 06, 2004 at 09:20:07 from (64.80.110.15):
In Reply to: Re: Left tractor tire sticks when cold posted by Okie Dave on October 05, 2004 at 17:12:25:
Nice try. The 706 does not have a park brake, it has a park lock. Unlness everything is terribly worn, you can't put the tractor in gear with the park lock engaged. If you do manage to get it in gear, it makes such a crunching, clattering racket that it's pretty obvious something's wrong.
If you leave the tractor in gear instead of engaging the park lock, it will roll away. The hydraulic TA does not engage without hydraulic pressure, so there is no solid connection between engine and transmission.
Post a Followup
Subject:
