Re: Off Topic/ Well help
Posted by John A. on October 07, 2004 at 20:40:17 from (65.161.170.179):
In Reply to: Off Topic/ Well help posted by Gorilla on October 07, 2004 at 17:55:46:
Gorilla, Set up an ol windmill, let it pump into a 6000gal storage tank.Then use the shallow well jet-pump to make pressure for the system.
You can kill 2 birds with one stone. Have the asthetics of an windmill on your place and a large supply of water on hand for your home/farm use.
Your well may not be able replenish very quickly after it has been drawn down. The rate of replenishment will dictate wheather or not you can stick a electric pump in the well and let it run with out worry of running dry for a short time. Or you many need a monitor that will keep the pump from burning up if it does run dry.
My place has the above setup with the windmill and storage tank. Hope this helps.
Later,
John A.
Post a Followup
Subject:
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
