Re: Oil blow bye on rebuilt motor
Posted by magman on October 10, 2004 at 07:02:01 from (64.12.117.22):
In Reply to: Oil blow bye on rebuilt motor posted by Bill from Seneca,IL on October 10, 2004 at 06:18:22:
Are you sure its blow bye?? While running tractor after it gets hot are you seing blue smoke coming from the exuast pipe? Is it just at start up?
Someone has exsplained it better on the board than I but I beleve its typicaly when the oil is alowed to by pass the compression rings going to the top of the cylender. Causing blueish smoke when you run it. Thus a brand new motor could have blow bye becuase of rings not seated yet to cylender wall. Older tractor with worn out rings would do it becuase there not seating becuase of wear to rings and cylender walls.
JON
Post a Followup
Subject:
