1256 stumper
Posted by tomy t on October 10, 2004 at 12:06:56 from (12.64.66.82):
we have 1256 that is putting pressure in the radiator.weve replaced the thermo 3 times. the local garage tested and found that it is carbon dioxide. seems to slow down when engine is wide open.when slowed down it starts pushin water out
on the ground.the block is slightly cracked behind the fuel pump but has only seeped coolant for a long time.any thoughts??????????
Post a Followup
Subject:
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
