Re: MVC Pump on IH 856
Posted by Aces on October 10, 2004 at 19:10:58 from (65.54.98.29):
In Reply to: MVC Pump on IH 856 posted by Spencer on October 10, 2004 at 17:45:22:
Spencer not much to it. There is a drain plug in the TA housing drain all the oil you can drain from that plug. There are two hydraulic fittings on the front side of the MCV and a number of hex cap screws to remove. When you remove the MCV look for a white plastic valve at the rear lower corner some times the oil will push it out and you miss it if you do you will not have steering after you go back together, make sure the suction oring and tube are good. I would change filter as well. Hope this helps
Post a Followup
Subject:
