Re: MVC Pump on IH 856
Posted by K.B.-826 on October 10, 2004 at 19:37:03 from (209.163.43.102):
In Reply to: MVC Pump on IH 856 posted by Spencer on October 10, 2004 at 17:45:22:
I'd get some advice from your Case-IH dealer first. There were some different thickness gaskets used, so hang on to your old gaskets to make sure you get the same ones back in there. There was a service bulletin giving a torque sequence for the bolts holding the MCV to the transmisson case. Make sure to get a copy of that, or you'll have leaks. When removing the MCV, don't remove the four bolts in the center, they hold the pump to the valve.
Post a Followup
Subject:
