Re: H motor missing under load
Posted by Wayne Swenson on October 12, 2004 at 16:25:59 from (66.191.70.4):
In Reply to: H motor missing under load posted by Pat B in Mich on October 12, 2004 at 09:38:18:
You may have a fuel mixture problem after the work you did to the engine. Be sure the carburetor isn"t your problem.
With the engine warm & running at wide open throttle (WOT), turn high speed mixture screw in until the engine begins to starve for fuel. Then turn the screw out until it begins to blubber. Now find the "sweet spot" in between the two settings. If you are working the engine (plowing, etc.), then the high speed screw needs to be turned out 1 turn or more beyond the "sweet spot" to be sure the engine isn"t starving for fuel and can develop its rated power.
The same procedure can be followed for idle mixture with the addition of the ldle stop screw to set the low speed RPM.
On the "H" carb, the idle mixture screw is an air adjusting screw so turning in will richen the mixture and out will lean the mixture.
Aren"t carbs fun!!
Post a Followup
Subject:
