Farmall Tractors Discussion Board
Re: Diesel problem
Posted by JK MN on November 16, 1999 at 08:22:01 from (207.242.199.131):
In Reply to: Diesel problem posted by John R on November 15, 1999 at 21:05:33:
John R
Since that engine starts on gas (low compression), and then is switched over to diesel, (high compression), be sure the compression release system is working properly. ie the compression release valves adjusted correctly, and also the engine valves adjusted correctly. Since only the head was worked on, I would first start in this area.
Post a Followup
: Re: Re: Diesel problem
