Re: Noise in 1941 A transmission
Posted by gene b on October 14, 2004 at 03:41:08 from (66.43.221.243):
In Reply to: Noise in 1941 A transmission posted by New Collector on October 13, 2004 at 18:08:36:
The oil slinger is no big deal as it basickly is for lube to the pto assy. You can get good ones used for 40bucks and new ones from I-H are four or more times that. You do have to split at tne front of the tranny and if you dont have any experience will be quite a job as the clutch and left brake pedals have to be unfastened at the platform to move ahead with the front of the tractor when splitting. The oil slinger is on the bottom and the back of the counter shaft in the tranny. I would also replace the input bearing on the tranny with a new seal. I can do this in 4hrs but have roller stands and have done it several times. Pull the tranny cover off and you will be able to see this slinger sprocket to verify if it is your trouble. good luck gene b
Post a Followup
Subject:
Today's Featured Article - The Great Escape - by Dave Hollrah. It all began Monday with a little baling of second crop on the lake shore field, and as I drove out past my sister and her hubby's place, this small calling sound could be heard from the general direction of their manure pile. Out of the yard, over the cows and bale piles, through the dozer piles, poplars, and brush, out onto the ditch grade road, past the noisy 6.2 diesel engine pulling my well traveled Suburban along. Well it sure didn't take me long to figure out what it was because I alrea ... [Read Article]
