Farmall Tractors Discussion Board
Re: H and problem 5th gear
Posted by The Red on November 16, 1999 at 14:09:55 from (12.50.208.126):
In Reply to: H and problem 5th gear posted by 41 H on November 16, 1999 at 10:18:40:
Define "stall out the motor". Is it sputtering and dies? Or do the RPMs decrease as you go uphill. If the latter, then I suspect a weak governor spring. Otherwise the other suggestion sounds like a good idea. Maybe running a tad lean.
Post a Followup
: Re: Re: H and problem 5th gear
