Re: Hydraulics 101
Posted by Wayne Swenson on October 16, 2004 at 18:21:36 from (66.191.70.4):
In Reply to: Hydraulics 101 posted by Dave D on October 16, 2004 at 17:16:36:
Run the tractor and set the bucket on the ground.
Shut the engine off & move the hydraulic controls in all directions to release any residual pressure.
When loosening the first fitting, drape a shop towel or grease rag over the fitting as you loosen it. Have a container under where you are working to catch the drips.
After re-assembly, just operate the loader through full range of motion and the air bubbles should work their way out of the hoses.
Re-check the fluid level, adding to compensate for lost fluid.
Post a Followup
Subject:
