Re: Farmall M jumps out of 5th gear
Posted by DWV on October 16, 2004 at 20:16:17 from (152.163.101.13):
In Reply to: Farmall M jumps out of 5th gear posted by CWally on October 16, 2004 at 18:38:55:
Even though 5th is straight through the input shaft and 4th and 5th sliding gear are not the same as stock M.You may get lucky and have problem
with shifting fork or ball and spring.If not one or both gears or a bearing is bad.
Post a Followup
Subject:
