Re: I have confused myself_which WF should I get?
Posted by David B on October 17, 2004 at 19:17:54 from (65.173.238.172):
In Reply to: I have confused myself_which WF should I get? posted by MM_TX on October 17, 2004 at 19:01:29:
With the old IH wide front, it takes about 40 acres to turn it around, unless you have the adapter plate to make it short wheel base, then it only takes 20 acres to turn.
Personally, I am cheap and would go with the old IH, even though it takes awhile to turn it, and it sticks out funny. I would rather have it correct, in case I ever wanted to restore it.
They're all good widefronts- if you want the tie-rods behind, go with the late IH instead of the Shwartz- then it would be somewhat correct. Plus, I believe the IH is more valuable than the Shwartz.
Just my thoughts
Post a Followup
Subject:
