Re: IH 300 Utility Hydrualic Valve leaking???
Posted by Unreserved dick on October 17, 2004 at 20:34:31 from (4.228.126.167):
In Reply to: IH 300 Utility Hydrualic Valve leaking??? posted by Scott Eakers on October 17, 2004 at 19:30:05:
They're not too bad if you're comfortable working on mechanical stuff. Main thing with hydraulics is to be clean - get the exterior clean before starting.
The shaft you're describing seals with small o-rings (available at CaseIH). You should also plan on replacing the o-rings between the valve blocks, reservoir, and end plate (3 req'd for each seam), and you'll need a new gasket for the valve's front cover plate. Good luck.
Post a Followup
Subject:
