Oiler gear problem on 1941 A
Posted by New Collector on October 17, 2004 at 21:01:30 from (66.79.194.97):
Thanks for your suggestions on my previous question. I took the top cover off the transmission and you guys were right about the oil slinger; the teeth are all broken off. I can't fix the oil slinger until next spring so I'd like to run the tractor without the pto and I know not to idle it in neutral. My question now is with all the teeth are off the slinger gear can I leave the remaining center piece on the shaft the way it is or should I try to crack it off with a chisel? Or can I just clean out all the metal pieces, flush it out and refill with clean oil? Thanks in advance for your help.
Post a Followup
Subject:
