Re: I have confused myself_which WF should I get?
Posted by captaink on October 18, 2004 at 08:28:53 from (66.115.214.56):
In Reply to: I have confused myself_which WF should I get? posted by MM_TX on October 17, 2004 at 19:01:29:
I’ve had two Schwartz wide front ends on my M. It has live hydraulics, 12 volt start, 15.5-38 tires on 14” rims, Behlen power steering and a DuAll 325 loader on her. I used to work it almost every day when I still farmed, now it just does odds and ends around the yard. The front end I currently have is a heavy duty one with 6-bolt hubs that I have 8X16” rims on with 236-16” load range E used pickup on. I can’t think of a drawback to it.
I have never had a genuine IH wide front, so can’t give any info on it, but did have hubs that took the original M front rims that clamped on like the rear wheels. I hated that one as the rims would work loose, turn on the hubs and sheer off the valve stems. Welding blocks that fit the notch in the hub eliminated the valve stem problem, but the rims still worked loose. I like the 6-bolt hub a lot better.
Post a Followup
Subject:
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
