Re: engine problem
Posted by El Toro on October 18, 2004 at 15:28:10 from (205.188.117.22):
In Reply to: engine problem posted by davidw on October 18, 2004 at 14:18:01:
Hi, Disconnect the fuel line at the carburetor
and see if gas flows freely. If it doesn't flow out you may have blockage in the tank or sediment bowl.
If the gas flow appears ok, your carburetor
probably needs to soaked in carburetor cleaner and cleaned thoroughly and install a carburetor
kit. Check for varnish deposits in the tank too.
Good Luck, Hal
Post a Followup
Subject:
