Re: is my turbo weak? 1066 smokes bad
Posted by Allan in NE on October 19, 2004 at 14:28:16 from (148.78.243.25):
In Reply to: Re: is my turbo weak? 1066 smokes bad posted by rustyfarmall on October 19, 2004 at 14:01:38:
Sounds "xactly like an injection pump goin" bad.
However, if that turbo has a seal leaking and it"s pushing lube oil out the exhaust it could cause a bit of smoke. But, this ususally shows up as a messy leak at the turbo area too.
Whaddda mean, you"re no diesel expert, Rusty? Ya are too! :>)
Allan
Post a Followup
Subject:
