Farmal B timimg
Posted by Elmer on October 19, 2004 at 15:38:56 from (69.58.141.109):
I've got a B that hasn't been run in 15 years. I think I've done everything I need to do to get it running. Gas, carb, points, condenser, plugs, wires. One piston has very little compression. spark is good. But it won't run. Should the impulse snap exactly on TDC? I can't move the mag enough to make it do that. Is there another way to adjust the timing?
Post a Followup
Subject:
