Re: is my turbo weak? 1066 smokes bad
Posted by Chuck's Repair on October 19, 2004 at 18:38:03 from (216.170.58.10):
In Reply to: is my turbo weak? 1066 smokes bad posted by ohjeffoh on October 19, 2004 at 07:06:17:
I believe the intake boost pressure on that tractor should be about 16 psi at full load.I'm pulling that figure out of my head.It's been several years since I've checked one but that should be close.If the HP has been turned up it will be higher.Bad injection nozzles will also cause this problem.Don't overlook a flat camshaft.If the valves are not fully opening it can't breath properly
Post a Followup
Subject:
