Re: Farmall H Disc Brakes
Posted by D Slater on April 03, 2009 at 12:24:26 from (72.65.152.236):
In Reply to: Farmall H Disc Brakes posted by Trader George on April 03, 2009 at 10:57:16:
If its the type sold by IH as a attachment or by a aftermarket company, the answer is yes if you get all the parts with them. If its the type IH installed on late H the answer is no, unless you change the differential, bull pinion gears, differintial carrier housings and all outside brake parts including brake, clutch pedal parts. If it has 3 bolts holding brake housings on its the former. if it has 5 bolt IH type.
