Re: Farmall H won't lean out
Posted by Bob M on October 20, 2004 at 06:41:50 from (165.170.128.65):
In Reply to: Farmall H won't lean out posted by farmallwayne on October 19, 2004 at 21:20:46:
A distillate carb in good shape can be adjusted to run fine on gasoline. From your description it sounds as if the idle circuit on your’s is inoperative (plugged).
Suggest you tear down the carburetor and give it a thorough cleaning. Pay particular attention to the idle passages and ports in the throttle body casting – that’s where the problem will be. Once the carb’s back on the tractor adjust the idle mixture first for a good idle, then set the high speed screw so you get a clear exhaust at governed RPM.
Unlikely your problem is magneto/plug related. It’s the heat of complete combustion – not the spark – that prevents carbon from building up on the plugs. Your carburetor is running rich. The resulting incomplete and relatively cool combustion is causing soot (carbon) to accumulate on the plugs and fouling them out.
Post a Followup
Subject:
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
