Re: Farmall H won't lean out
Posted by John *.?-!.* cub owner on October 20, 2004 at 06:45:19 from (208.54.220.24):
In Reply to: Farmall H won't lean out posted by farmallwayne on October 19, 2004 at 21:20:46:
We used a dual fuel H exclusively on gasoline for many years, with the original carb, and had no problem adjusting it. While it does have seperate load and idle jets, they do have some interaction.
Post a Followup
Subject:
