Re: Super C DC 1-4 Flywheel mark, Clutch housing c
Posted by Peabody on October 20, 2004 at 08:05:35 from (24.179.12.21):
In Reply to: Super C DC 1-4 Flywheel mark, Clutch housing cover posted by JBlavl on October 20, 2004 at 07:57:56:
You've got it right. Unfortunately, the DC1-4 mark tends to be extremely faint, someone marked mine with some white paint to make it easier to see. Personally, I would rather use a stiff wire stuck in the #1 cylinder spark plug hole and turn the belt pulley until I find #1TDC. You can do this and watch the position of the rotor to know when you are on the compression stroke, and you don't have to crawl up under the tractor and fool with a flashlight or drop light.
Post a Followup
Subject:
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
