Re: Farmall B rescue mission is on!
Posted by Red Dave on October 21, 2004 at 07:00:46 from (24.104.94.34):
In Reply to: Farmall B rescue mission is on! posted by Jeffer on October 21, 2004 at 05:32:15:
16 feet is plenty lomg enough, but 6 1/2' wide may be a problem. My B is about 78 inches wide, outside rear tire to outside rear tire. About 7 or 8 inches wider at the hubs, but if your trailer sides are not higher than about 14 inches or so, hub width won't matter. This is with 9.5 X 24 tires. Depending on how the wheels are set, it could be wider. Wheel weights will add to the width too, if you have a high side trailer.
It may be a good idea to take along a jack and some tools in case you need to move the wheels to make it narrower to get it on your trailer.
Post a Followup
Subject:
