Re: Farmall B rescue mission
Posted by Red Dave on October 22, 2004 at 05:14:21 from (24.104.94.34):
In Reply to: Farmall B rescue mission posted by Jeffer on October 21, 2004 at 19:34:30:
Jeffer, There is one thing I forgot to tell you below.
My B weighs 2140 lbs. That's with no water in the tires, no wheel weights, half tank of gas and the seat empty. That's with the stamped steel dish wheels, add 300 lbs each if yours has the heavy cast wheels. Drawbars were on, but no other attachments.
Rear wheel weights weigh about 140 lbs each, if yours has them.
Hope that helps,
Good Luck!
Post a Followup
Subject:
