Re: Cub crank pully
Posted by John *.?-!.* cub owner on October 22, 2004 at 06:56:17 from (208.54.220.24):
In Reply to: Cub crank pully posted by Harris on October 21, 2004 at 20:32:19:
The only easy way is to have someone else do it. If you pull on the flanes it WILL break, not maybe break, will break. It requires a bearing seperator or something similiar that will grip the heavy part behind the flange and a heavy duty 2 jaw gear puller. somtimes also take heat. Try going to www.faramllcub.com and doing a search for cran pulley or crankshaft pulley. I believe there may also be some tips on Rudi's manual web site at the lik below.
Post a Followup
Subject:
