Re: SMTA Clutch
Posted by captaink on October 22, 2004 at 07:25:47 from (66.115.214.56):
In Reply to: SMTA Clutch posted by FM on October 21, 2004 at 19:24:05:
My 2 cents. I have nothing good to say about a button clutch. In my opinion they don’t even make good scrap metal! I have had experience with them in a 560, 966, and 1486 tractors. They all shifted hard and were almost impossible to get moving smoothly. That being said here’s the technical side as to the way I feel. First, they tear up flywheels and pressure plates left right and sideways because they are or at least were usually made of such a hard material. Every time they slip they remove metal from either or both. I will guarantee that if you ever have to replace the clutch disk you will have to either resurface the flywheel or even replace it because it will be worn that bad. Pressure plate is an automatic replace with the disc. Second, they get harder and harder to feather and get into gear as they wear and chew up the flywheel and pressure plate (see first above). This is because they start to wear a curve on both the inner and outer radii of the clutch. This tends to be accentuated if the clutch and flywheel heat up. One theory is that the disc will actually stick to one or both making it almost impossible to get the transmission to stop. Hmm might be one reason IH started putting a brake in the transmissions later on. Also leads to them being more jumpy when engaging. Third, the button clutches have a habit of breaking the shock absorbing springs in the hub of the disk resulting in premature failure of the clutch, leading to first above. I believe this is due mostly because of second above. I think by now you have the picture. I hated them so bad, my solution on my hybrid 966 (436 crank & pistons, 1466 flywheel, clutch, & blower, and 1066 air cleaner & hood) was to have a local clutch manufacturer (now out of business) put together a fiber button clutch that had enough buttons on it that it was practically a full faced fiber clutch. Made that 966 a fantastic loader tractor (for a non-hydro) lots of lug (thanks to the 436 crank & flywheel) smooth shifting (thanks to the fiber clutch) and pretty economical (thanks to the blower). Now the disclaimer…technology moves on, and there may have been improvements the past 5 years that I’m not aware of. If so, please take them into consideration also when you make your decision. Main thing on a clutch is make sure the flywheel and pressure plate are flat, the clutch springs are all the proper strength (might consider heavier ones if slipping is a concern), and that the fingers on the pressure plate are set correctly allowing proper clutch adjustment. I believe that a full faced fiber clutch set up right will live up to your expectations.
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
