Re: No spark on Farmall Cub
Posted by Terryc on October 23, 2004 at 15:21:00 from (69.60.227.62):
In Reply to: No spark on Farmall Cub posted by Magnut28 on October 23, 2004 at 14:37:18:
it could be the coil, but before changing any parts it's a good idea to check for the real problem. A little late now so much harder to do. Parts get expensive after changing evrything. First did you check to see that the points were operating properly? check point gap? check for spark there first. then move back from there. if you had spark before it isn't likely to be gone now, just something out of whack. also check wires into and inside distributor to be sure there are none bare or rubbing on metal and that you reinstalled insulating washers properly on distributor connection.
Post a Followup
Subject:
Today's Featured Article - The Great Escape - by Dave Hollrah. It all began Monday with a little baling of second crop on the lake shore field, and as I drove out past my sister and her hubby's place, this small calling sound could be heard from the general direction of their manure pile. Out of the yard, over the cows and bale piles, through the dozer piles, poplars, and brush, out onto the ditch grade road, past the noisy 6.2 diesel engine pulling my well traveled Suburban along. Well it sure didn't take me long to figure out what it was because I alrea ... [Read Article]
