Re: Super A Generator
Posted by gene b on October 23, 2004 at 22:27:37 from (66.43.221.243):
In Reply to: Super A Generator posted by Scott KY on October 23, 2004 at 15:21:12:
Did you polarize it with the engine off. Use a jumper and momentary go from the A terminal on the gen to the Batt term on the cutout should draw a spark. Then if it doesent charge with the engine running ground the field term on the gen. If it charges with the gen F term grounded the cutout is bad.or has a poor ground to the gen. You can run with the FIELD term grounded aslots of them are running that way. Does your generator have the third brush that is adjustable?
Post a Followup
Subject:
